tfl unicorn
Discussion dans 'News Crawlers / Scales' créé par LIPFI, 10 Juin 2019.
  1. LIPFI
    LIPFI membre
    12 Mars 2015
  2. CyberFox
    CyberFox membre
    17 Mars 2009
    tu pourrais enrichir un peu ton sujet, plutôt que mettre uniquement un lien interminable que mon navigateur ne veut pas aller voir ? :D
    hanjin-san apprécie ceci.
  3. Reptile81
    Reptile81 membre
    C'est un kit, assez beau, voir même très beau:D
    et ça:
    Note:
    1.This car is unassembled kit,the package are all parts,you need to assemble by yourself
    2.This car will be available in May,more detailed pictures should be updated later
    3.This car do not have motor,esc,servo,transmitter,car battery,charger and stickers
    Features:
    1. All-metal pipe rack design adopts hollow stainless steel pipe to ensure the weight and reduce the center of gravity while taking into consideration the strength. make It more easier to control the car.Metal pipe 620g
    2. The design of the pipe rack refers to the design of the real car, which restores the appearance of the real car to the highest degree.
    3. The complete interior design is retained, in 3D printed form, and can be colored in the later stage.
    4. The interior is equipped with a simulated steering wheel, racing seat and shift lever.
    5. The gearbox is equipped with an external 3D printed decorative piece, which can be colored by yourself.
    6. This car uses a front-mounted all-metal two-speed gearbox. The CNC machining format guarantees accuracy and strength. The two-speed design takes into account the climbing and speed, and adds a back-propagation system.
    There are two gears, the high gear ratio is 7.2:1, the low gear ratio is 21:1, and the double speed gearbox (that is, the two speeds can be adjusted)
    7. The all-metal axle adopts CNC machining form to ensure accuracy and strength.
    The axles of the C1402 diamond bridge (AXIAL WraithRR10 scale), all-metal CNC axles, with a new design of improved steering CVD working angle will be greater.
    8. The front axle steering system adopts the form of rear steering gear, which is more beautiful
    9. The front axle steering CVD uses high-strength materials to ensure strength and steering angle.
    10.Performance: High speed and climbing matching, because of the all-metal pipe rack and axle, the car will look better than plastic and nylon ones
    11.Two-speed device, high degree of simulation,The ratio is 1/8, and the size ratio is based on AXIAL RR10.
    Package included:
    1X Rc Car Unassembled Kit(Without motor,esc,servo,car battery,transmitter and charger)
  4. LIPFI
    LIPFI membre
    12 Mars 2015
    Je suis pas une balle en informatique mais le lien marche de mon portable
  5. Reptile81
    Reptile81 membre
  6. CyberFox
    CyberFox membre
    17 Mars 2009
    merci reptile, ce lien fonctionne chez moi (y)
    je me demanderai toujours comment on peut aller sur le web avec un téléphone portable et son petit écran incapable d'afficher pleinement les pages www sans nous exploser les yeux o_O
  7. tchoupy57
    Ben tu achète un grand portable :hihi:
  8. CyberFox
    CyberFox membre
    17 Mars 2009
    C'est ce que j'ai fait, j'en ai un de 12 pouces et un de 14 pouces.
    Mais ils ne font pas téléphone, ils font seulement ordinateur :hihi:
  9. LIPFI
    LIPFI membre
    12 Mars 2015
  10. KRISTOF
    KRISTOF membre
    21 Juin 2012
    Salut la communauté,
    depuis que je l'ai repéré sur Hobbyking il me fait de l'œil, mon passage sur le site ne date pourtant pas d'il y a longtemps et il est déjà annoncé comme un produit épuisé.
    TFL Unicorn 1/10th Scale AWD Rock Buggy (Kit)
    J'aimerai bien en savoir un peu plus avant de faire chauffer la CB. Sauf erreur de ma part, je n'ai pas encore vu de post présentant son essai, d'où mon interrogation, qui en possède déjà un? ;)
    Merci.
    Reptile81 apprécie ceci.
  11. Edgar092588
    Edgar092588 membre
    30 Novembre 2016
    Moi ça me fait penser au capo jkmax le style
